LUK "REPSET" CLUTCH - NCRS Discussion Boards
LUK "REPSET" CLUTCH
  • Rob A.
    • December 1, 1991
    • 2126
    LUK "REPSET" CLUTCH
    I have seen favorable comments regarding the LUK "REPSET" clutch. Does the term "repset" refer to any specific type of LUK clutch, or just that it comes as a set, disc, pressure plate, etc? I am getting ready to order from them and want to make sure I am getting the same one I have seen positive feedback on.
    • 43205
    Re: LUK "REPSET" CLUTCH
    Rob-----
    I think it's just their term for a "repair set". If you get a LUK kit, it will be a "REPSET". This just means that you are getting the right SET of parts to meet your application's requirements rather than purchasing the individual pieces where one or more might be the wrong thing. If you get the RIGHT REPSET, you'll have everything you need.
    • Dick W.
      • 10483
      Rob, I have used several LUK clutches with absolutely no problems. I would not have any qualms about recommending them
      Dick Whittington
        "RepSet" is LuK's terminology for "Replacement Set" in their "Vintage Replacement" line of clutches. Good stuff.
        • Terry Leeker
          FYI Several weeks ago, I bought an original replacement clutch set from LUK for my '58, diaphragm type-bent finger(the original original was Borg and Beck type). Included was a pilot bushing. It was bronze appearing. To be on the safe side I checked it with a magnet. It was magnetic. Not wanting to take a chance, I bought a replacement bronze (non-Mag)bushing from the local auto parts store. Maybe the LUK version was a sinister iron/copper alloy - it was pretty soft. Anybody run across this before?
            Yup, a whole slug of offshore-produced counterfeit pilot bushings very high in iron content polluted the aftermarket parts systems about two years ago; the "real deal" bushings are made from Oilite bronze and have no ferrous content. NAPA, for example, got thousands of them - good idea to check any pilot bushing you buy with a magnet - steel rubbing on iron isn't a formula for longevity.
            • Donald M.
              • December 1, 1984
              • 498
              John, I read your reply with interest. But,what is "Oilite" material? Is it impregnated with lube?
                Yes - Oilite bronze starts out as "powdered metal" bronze, and is combined with a lubricant and then compacted/forged to final shape under extreme heat and pressure; the process was invented/patented by Chrysler in the late 30's.
