How bout that PVC fitting at the back of 327s? - NCRS Discussion Boards
  • Tracy C.
    • July 31, 2003
    • 2739
    I confess, I was temped to scour the research books for the answer fer my question but then I caught myself...
    Decided to tap into this pool of expertise......duh!
    At the back of my 63 block next to distributor is what looks like a PVC fitting. Also has another on the oil fill tube.
    Where do these buggers plumb to?
    tc
  • Geoff C.
    • May 31, 1979
    • 1613
    Simple "buggers plumb" is in the AIM *NM*
    • Mike M.
      • May 31, 1974
      • 8383
      Re: How bout that PVC fitting at the back of 327s?
      Rubber grommet presses into top of engine case to drivers side of distrib. then a swedged pipe inserts into the grommet then a rubber hose inserts over the pipe and the rubber hose inserts over the pvc valve fastened to the carb(all this non fi info) mike
      • Tracy C.
        • July 31, 2003
        • 2739
        Mike,
        I was planning on cobb'n one from a 66 donor motor. There is no rubber grommet involved, but rather a "press in" type metal fitting with a 1/4" bolt through the middle into the block.
        From your input, I assume this would be incorrect? (I haven't looked to see if I have a tapped hole to accomodate the bolt)
        tc
        • Geoff C.
          • May 31, 1979
          • 1613
          It could not be clearer in the AIM
          Honestly
          • Bob R.
            • June 30, 2002
            • 1595
            Re: It could not be clearer in the AIM
            Long Island Corvette's catalog shows a clear picture of the proper plumbing and will even sell you the parts.
              Be sure you get the "'63-only" parts; the airflow in the crankcase ventilation system (and thus its plumbing) was reversed in '63 vs. '64 and later. All is shown in the A.I.M.
              • Tracy C.
                • July 31, 2003
                • 2739
                Thanks for the help *NM*
