C3 1972 Alarm System ORGINIAL RELAY # - NCRS Discussion Boards
  • JOHN WILSON
    Could anyone tell me the correct flasher relay for a 1972 Alarm system.
    the one in my 72 has IDEAL CORP 536HW HEAVY DUTY FLASHER written on it.
    Re: C3 1972 Alarm System ORGINIAL RELAY #
    If memory serves your AIM book will call out several PN's (alternate suppliers) and this flasher PN (alarm) should dovetail to what's used in the 4-way emergency flasher position (fuse block mounted). One of the recognized vendors (memory says there were three qualified) IS Ideal Corp with its 536 model....
    If you remove the flasher from its mounting clip and look CLOSELY at the can, you should be able to makeout the DOT date code for the flasher assy! look for a three number embossed sequence with the first two digits being the week of the year and the last being the digit of the year of manufacture.
      • 43221
      John-----
      None of the 3 flashers used in PRODUCTION for this application were ever available in SERVICE. The SERVICE replacement for the last 20+ years has been GM #491391. You can still buy it today from any GM dealer. It may or may not be similar to your original in terms of configuration. It will be entirely functional, though.
        • May 31, 2002
        • 169
        John, if you hold your relay between your legs while looking in a mirror
        you should be able to make out what a ---head you are. Just kidding. Big John
        Please e-mail me with your active e-mail address. I am unable to e-mail you.
        I did get in touch with Keith.
