C2 cluster rebuild - NCRS Discussion Boards
C2 cluster rebuild
  • Jeremy Hedges
    C2 cluster rebuild
    I am in the process of rebuilding my instrument cluster in a 65. I recall (I think)that there was some kind of insulation or sealant around the gauge lenses. I can't remember if it was between the lens and housing or the lens and gauge face or both? Or am I dreaming? If it did have something, what should I use as a replacement?
    Jeremy Hedges
  • Bob R.
    • June 30, 2002
    • 1595
    Re: C2 cluster rebuild
    On my 63 there was a black material between the lens and the cluster housing. There are 4 small grooves in the housing at each lense. The material was in the grooves. I used some rope caulk that I got at a hardware store. It seemed to be the correct texture. It feels like puddy.
    • Joe C.
      • August 31, 1999
      • 4598
      There are small rectangular rubber insulators---three around each small lens, and four around each of the 2 large lenses. Not sure if the large parts houses have them. Maybe somebody like LICorvettes Doc Rebuild, or Chicago Corvette. If not, the better rebuilders will sell you a set: that's where I got mine.
      Joe
      • Dave K.
        • November 1, 1999
        • 952
        Check the ZIP products web site under technical articles for a step by step set of instructions with pictures of a C2 cluster rebuild.
        Dave Kitch
