Right vs Left - NCRS Discussion Boards
Right vs Left
  • Jim Damasiewicz
    Right vs Left
    When manuals reference right vs left, is rigth the driver side or passenger side?
  • Steve Miller #39713
    Re: Right vs Left
    Passenger side.
    • Bill B.
      • September 30, 2002
      • 351
      Re: Right vs Left
      I remember by sitting in the driver seat(provided you are looking forward)-driver is left and passenger is right
      • Donald L.
        • September 30, 1998
        • 461
        Re: Right or left odd or even
        GM solved this situation by assigning part #s with the last number odd as being the driver side and even number being the passenger side.
          • 43238
          Donald-----
          For the MOST PART and covering about 99.5% of the cases, that's the way it was/is. However, there are exceptions. It's not a hard-and-fast rule.
          • William V.
            • December 1, 1988
            • 399
            Re: Right vs Left & Port vs Starboard
            Both are the same. While facing forward only.
            • Roy B.
              • February 1, 1975
              • 7044
              Donald is right 13579 numbers are L/S and 24680 numbers are R/S, but if the part can be used on eather side or it's a one time pieace like your steering wheel it can end with any odd or even number.
              • Wayne W.
                • April 30, 1982
                • 3605
                Re: Not a Hard and Fast Rule
                For instance the 65 interior door pull is numbered like you would expect with the odd number on the LH side, but when this part was reused on the 69-75 cars it was used on opposite sides, thus the numbers are reversed.
