Door Glass Installation Mid-Year Coupe - NCRS Discussion Boards
  • Dennis M.
    • April 30, 1988
    • 160
    I have tried several ways to get the vent window and door glass back in a 64 coupe. I had the door glass in then tried to install the vent window, can't do. Installed vent window and then tried glass with the rear runner installed can't do; tried with the rear runner out then installed the runner without the liner and all was good until I tried to install the liner. Got the the top half around the window but could not get it into the runner with the glass in place. I know there has to be simplier method to doing this. Looked at the assembly manual and the 63 GM Service Manual, which shows removing glass but not for a coupe. Talks about it but the pictures are for a roadster.
  • Timothy B.
    • April 30, 1983
    • 5190
    Re: Door Glass Installation Mid-Year Coupe
    Hi Dennis,
    I have not done mine but I plan on installing the top window felts which snap in, then the vent window and frame followed by the window and regulator. Do not try to install the lower rear window track until after you install the window because this way you will have enough room to lower the window into the door and slide it forward into the front track. After that try raising the window to a closed position and then install the rear lower channel through the side access hole. I hope this helps you out. Tim B
    • David Z.
      • April 1, 2002
      • 181
      Dennis
      Send me your e-mail address and I can send you some info on how my wife and I did this job on both doors last summer.
      Dave Z
      Dave Zuberer
      • Dennis M.
        • April 30, 1988
        • 160
        Dave and Tim,
        Thank you for your inforamtion, I have completed the passenger door and will work on the driver's door on Friday.
        Thanks & Save The Wave,
        Dennis
