C1 BODY SHIMMING - NCRS Discussion Boards
C1 BODY SHIMMING
  • Joe D.
    • April 30, 2002
    • 382
    C1 BODY SHIMMING
    The AIM shows a rubber shim (for the bolts) on the frame, then a metal shim on top of that. Then the body. I bought a body mounting kit, the instructions show the metal shim on the frame and the rubber shim on top of the metal shim. It seems that the rubber shim should be in contact with the body, not the metal shim. Do the rubber pads go across the frame or do they go paralell with the frame. Thanks as always. Joe DeLuca #37862
  • Ray C.
    • June 30, 2001
    • 1132
    Re: C1 BODY SHIMMING
    Hi! Joe
    I am in the process of lifting the body off my 61. I checked the body mount in front of the right door and it was frame, rubber, shims, 1/2 to 5/8 tape and body. I will email you a picture.
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
