68 Radio just hear it - NCRS Discussion Boards
  • Roy B.
    • February 1, 1975
    • 7044
    I can just almost hear the radio when turned up , what is the problem?
    • 43221
    Re: 68 Radio just hear it
    Roy------
    Likely, either the externally mounted convector unit is not attached to the radio or the germanium transistor which is the core component of the convector has "expired".
    • Roy B.
      • February 1, 1975
      • 7044
      Where is the convector ? is there an other part from the radio bad
      • Craig S.
        • June 30, 1997
        • 2471
        Roy - the convector is a unit behind your right had dash pad, under the dash. It is basically the power transistor/heat sink assembly on the output stage of the radio....Craig
        • Roy B.
          • February 1, 1975
          • 7044
          Re: 68 Radio just hear it craig
          Will one from a 69 work ? I have one from a 69
            • 43221
            Roy-----
            1968 and 1969 convectors are the same.
            • Roy B.
              • February 1, 1975
              • 7044
              Re: 68 Radio craig thanks *NM*
