Pardon the very simple questions but I am haveing trouble figuring these out, especialy since many electrical components aren't working. '72 BB
1) The three knobs under the stearing column, two are pull down and one seems to twist. What are their function? The two that pull down look like they have two hoses each attached to them runing threw the fire wall.
2) Behind the passanger seat in the storage compartment there is the fuse relay for the flashers. What is the "relay" next to it, rectangle with a white, black and (I think) orange wire conecting to it?
3) Again in the same storage area and not connected to the relays there is a black wire with a conector on the end and a an orange wire, mine has been cut. What are these for?
Thank you,
Brandon
Thank you,
Brandon
