'53-'55 washer bottle/bracket questions - NCRS Discussion Boards
  • George W.
    • May 31, 2000
    • 544
    I do not own a '53-'55 vette , so my library for these parts is limited to Nolan Adams "The Complete guide.........." -- first edition . I have what I believe to be a never installed washer bottle , bracket , lid w/two nozzels(one plastic , the other metal) , and the "innards" attached to the top which goes down into the bottle . According to what I can see on page 32 , the bracket seems to be an early '53 (narrow top strap) . All diminsions are the same , but someone has advised me that Corvette brackets had only one mounting hole on the bottom ( this one has two). The diagram on page 33 clearly shows two lower mounting holes , but this diagram is for a '55 bracket . I would like to send photos to anyone who could properly identfy these pieces . Thanks in advance , George
  • Roy B.
    • February 1, 1975
    • 7044
    Re: '53-'55 washer bottle/bracket questions
    George Yes the 55 has two lower bolts and two upper, the lid cover has two black plastic nozzels pointing in the same direction . it's the same as the 57 red top nozzels with a pick up rubber tube and sreen.
