69 SB Front Front Sway Bar - NCRS Discussion Boards
  • George D.
    • August 31, 2000
    • 225
    Can someone help me with the correct markings on the bolt heads for the bolts (the long ones with the rubber gromments) that attach the front sway bar to the lower control arms and where can these be purchased?
    • 43258
    Re: 69 SB Front Front Sway Bar
    George-----
    Among the headmarkings used were "WB2C" and "WB". Others may have been used, too. My 1969 originally had the "WB2C". I believe that Paragon reproduces at least one of these bolts.
    • Eugene B.
      • May 31, 1988
      • 710
      George,
      Joe is correct that you can get the link kit bolts from Paragon. I ordered this kit for my '65 with WB2C headstamps. Although the bolts have the WB2C headstamp, they are not a "dead ringer" copy of the bolts that were used on the '65. I'm choosing not to use them.
      Gene
      I
      • George D.
        • August 31, 2000
        • 225
        Thanks to both of you *NM*
