Multi-Battery Tender recommendation - NCRS Discussion Boards
  • Dino L.
    • February 1, 1996
    • 694
    What is the best product to use to maintain a charge and in general maintain the condition of my batteries. Can I purchase one tender and connect it to 5 different batteries during winter storage? what is th emake and model number and where can I get one...your recommendation please.
    Dino Lanno
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Multi-Battery Tender recommendation
    goto google and type in "battery tender" and you will get their website.
    • Eric Fairclough
      This is what i have been using for years now. I hook it up and leave it on all winter. Copy and paste the link below. Eric
      http://www.harborfreight.com/cpi/cta...emnumber=42292
      • Zachary K.
        • March 1, 1986
        • 162
        Excellent product worth every penny. Can be used with multi - battery hookups.
        1967 L79 Sunfire Yellow Black Leather Convertible- Duntov
        1969 L71 LeMans Blue, Bright Blue Convertible
        1970 L46 Monza Red, Light Saddle Convertible - Duntov
        1976 L82 Classic White, Firethorn
        2013 LS7 Black, Ebony, Convertible
        Moved on -
        2006 LS2 Black, Ebony, Convertible
        • Joe Pennington
          I have three of the Harbor Freight float chargers. Just hook them up and forget about them. They've worked for me. The store here in town has a sale on them from time to time at approx $9 each.
            • 11643
            Dino,
            I use the Battery MINDer. It has the advantage of being able to desulphate your battery. See the company's website for details. I bought mine from on of the repro battery guys at Carlisle. You can also buy them from Northern Tool.
            Patrick
            Battery MINDer
            • William V.
              • December 1, 1988
              • 399
              Do not connect batteries together.
              Each battery needs it's own tender
              1. the current output of the tender is low and will only keep one battery at the float voltage (12.8v to 13.2v) The tender will not charge the battery. The battery must be ar full charge for the tender to work.
              2. Batteries connected together in parallel without isolation diods and with no or very low input float current will go dead. they feed off each other and run each other down. One battery is always slightly lower than the other thus current is then passed from one to the other killing both.
              3. I also suggest disconnecting the battery when hookig up the tender. This ensures the car's electrical system is not loading down the tender
              I know this from my experience with dual batteries in boats. In a boat one should never leave the batteries unattended with the battery selection switch in the "both" position unless there is an isolation circuit.
                • 11643
                Bill,
                You're right about them needing to be fully charged at the outset, but the Battery MINDer specifically states that up to 5 can be hooked together, and gives instructions.
                Patrick
                • William V.
                  • December 1, 1988
                  • 399
                  KQQL
                  Never heard of a tender that could float 5 batteries at once. I'll have to check it out.
                  • Brian McHale
                    I smell smoke.
                    • Craig S.
                      • June 30, 1997
                      • 2471
                      Battery Tender's website.......Craig
                      Deltran Corp - Battery Tender
                        Great device - I've used them for years with no problem; hook it up, plug it in, and forget it. We also used them in the Viper Plant in the shipping room when finished Vipers destined for remote destinations (Alaska, Whitehorse-Yukon Territory, etc.) would sit for weeks at a time waiting to make up a full load (5 cars) for a Reliable carrier truck.
                        • Craig S.
                          • June 30, 1997
                          • 2471
                          I bought one of their high frequency jobbies they sell for several hundred dollars on Ebay a couple years ago for $50 from someone that got 10 from a fire dept that had them on a trial somehow. Has a microprocessor controlled charging curve...and a full 20A charge rate with the same trickle down management and control as the tender. Pretty neat device I thought.....Craig
