C3: Distributor Specs: Centrif/Vac Advance - NCRS Discussion Boards
  • Tony H.
    • May 31, 1993
    • 537
    I am interested in what the centrifugal and vacuum advance specs should be for 1970 LS5 Corvette. My distributor is not listed in the service manual (1969 Corvette listed as well as the specs for 454/390hp RPO LS5 Monte Carlo and Chevelle). Neither distributor matches the part number for the 1970 Corvette distributor.
    Tony
  • William C.
    • May 31, 1975
    • 6037
    Re: C3: Distributor Specs: Centrif/Vac Advance
    How about the number for the dist you are looking for?
    Bill Clupper #618
    • Tony H.
      • May 31, 1993
      • 537
      Re: C3: Distributor Specs: 1111464 *NM*
      Tony
      • William C.
        • May 31, 1975
        • 6037
        Curve start @1200 rpm 1-3 degrees 2100 rpm-15-19 degrees full advance at 3200 rpm 20-24 degrees Vacuum advance can Part # 1115360,
        Bill Clupper #618
          • 15676
          I believe the "360" vacuum can is 0@6", 16@12" - NAPA/Echlin replacement is VC1765. The ignition advance map might be included with the AMA/MVMA specs that are included with the GM restoration package available complimentary from Chev. Customer Service. They are for '63 - not sure about later years.
          • Tony H.
            • May 31, 1993
            • 537
            Duke, Bill,
            Thanks for the information. The vacuum advance can has 360 stamped on it so I think it is original. It also works (it holds under vacuum and moves the distributor vacuum advance plate). I want to generate the curve when I tune up my car and compare it to specifications. I am looking for the target spec and the allowable deviation will help, too.
            Does someone have the number to Chevrolet Customer Service? I remember trying to contact them years ago but got no response. What should I ask for?
            Tony
              • 15676
              Chev. Customer Service is 800-222-1020. If you want to expidite delivery of the package, call the contractor directly at 248-475-7372.
              • Chris H.
                • April 1, 2000
                • 837
                Tony, my original 464 distributor has a 360 can. It also has Tonowanda orange overspray on it, as well as a white "#6" written on it. Chris
                • Tony H.
                  • May 31, 1993
                  • 537
                  Tony
                  • William C.
                    • May 31, 1975
                    • 6037
                    I believe from looking at a lot of old distributors and chacking the application that you are correct re- the "6" (or whatever number is appropriate) is the initial timing setting for the distributor in the original application
                    Bill Clupper #618
