'67 BB WATER PUMP - NCRS Discussion Boards
'67 BB WATER PUMP
  • Rob A.
    • December 1, 1991
    • 2126
    '67 BB WATER PUMP
    I found quite a few recommendations fot Arthur Gould regarding water pump rebuilding. Is there something special about these older pumps that would require a particular rebuilder, as opposed to a shop that does it locally. (I'm in California, and it would be nice, for a change, not to have to send work across the country).
  • Mike M.
    • May 31, 1974
    • 8385
    Re: '67 BB WATER PUMP
    our machine shop here in a small towm in westerm maryland can rebuild a water pump. mike
    • Mark Skroupa
      Mike, what do they charge? I am in MD also.
      • Mike M.
        • May 31, 1974
        • 8385
        been about 10 yrs ago but think it was 30 frogskins. name of machine shop is S & S machine shop. located on henderson blvd, cumberland, md. dad(owner) retired about 4 yrs ago. name is dale simons, son known as junior, running it now. call info for phone #. its a typical mom and pop shop. good luck, mike
        • Craig S.
          • June 30, 1997
          • 2471
          Rob - nothing special at all....but make sure you tell them to use your original screws on the back, a correct cork gasket, etc. Not sure if it is safe to use the original pulley mount flange or not, but most rebuilders use the dual pattern unit with 8 holes since one part fits all. I expect Art would use the correct midyear hole circle pattern....just guessing...Craig
