Difference between 60 and 61-2 alum bell housing - NCRS Discussion Boards
  • Tom P.
    • April 1, 1980
    • 1815
    What are the specific differences between the 60 and the 61-2 aluminum bell housings? I've never seen the 2 side by side to compare them.
    • 43241
    Re: Difference between 60 and 61-2 alum bell housi
    Tom----
    The only difference between the 2 bellhousings (other than casting number, of course) is the size of the clutch fork opening. The 61-62 has a significantly larger opening.
    • Tom P.
      • April 1, 1980
      • 1815
      Thank you very much. I DID know that, but, if there were any other differences, I was unaware of them. It seems strange that the hole changed for 61, then changed again later on for the full enclosure (63-later) housings. As best I can tell, the 55-62 iron and 60 alum housings have the same size fork hole. I have a 60 alum on my 56 Vette (I don't remember the casting # and can't see it because it is covered up by the tranny) and the one I got at the swap meet Fri is the 553 for a 61-62.
      Do you know what the 60 casting # is?
      • Donald L.
        • September 30, 1998
        • 461
        #3764591 is the casting # for the 60 C-1.
        Reagrds,
        Donald #31176
          • 43241
          Tom------
          The 1960-only aluminum bellhousing was GM casting #3764591.
          The 1955 to 1959 CORVETTE cast iron, 1955-57 passenger cast iron, and 1960 CORVETTE do, indeed, have the same size clutch fork hole. However, I'm not sure about the 58-62 cast iron passenger car cast iron bellhousing. I think that it may have had the same size hole as the '553' aluminum bellhousing.
          • Tom P.
            • April 1, 1980
            • 1815
            Thanks. I guess I need to hang onto the 60 housing that is on my 56.
