60-2 HD BRAKE DRUMS ? - NCRS Discussion Boards
  • Loren L.
    • April 30, 1976
    • 4104
    what is the "drop dead" or throw-em-away-you-just-became-a-trailer-queen measurement for the insides of the drums? Thanks.
    • 43241
    Re: 60-2 HD BRAKE DRUMS ?
    Loren-----
    I realize that you are looking for a definitive answer here and, unfortunately, I can't offer that since I'm not a drum brake "kind-of-guy". However, the 57-62 HD brake drums were, I believe, 11" drums, which was the same diameter as the standard brake drums used for C1 Corvettes. So, I would expect the same "discard" thickness would apply.
    Generally, Chevrolet used to recommend a maximum REFINISHING bore size of, I believe, 0.060" over on these drums. Add to that about 0.015" for allowable wear beyond the maximum refinishing bore size for the "discard" thickness. So, mu GUESS would be that the discard bore size would be about 11.075".
    I would think that someone on the board would, at least, have a a standard drum handy to confirm that from the cast-in discard thickness embossing found on the drums.
    • Loren L.
      • April 30, 1976
      • 4104
      The HD drums were cut to a different
      finish - I suspect the tolerances might be different.
      • John M.
        • January 1, 1999
        • 1553
        Loren,
        This might not be of much help, but all the original standard drims that I have on the shelf are all marked with a 11.90 max size.
        Regards, John McGraw
          • 15696
          John means 11.090", which is correct! *NM*
          • John M.
            • January 1, 1999
            • 1553
            Duke is right! Pesky decimal point! *NM*
