restoring 65 center console - NCRS Discussion Boards
  • tim colleran
    What is the best way to remove the old shift pattern?
    What is the best place to get a new one?
  • Jace H.
    • April 1, 1997
    • 253
    Re: restoring 65 center console
    Very carefully pry it off with a putty knife or screw driver. I bought the resto kit from Long Island and have been pleased. However the shift pattern is not a perfect match to the original. I haven't seen one that matches perfectly. The spacing and thickness of the lines are the issue.
    Good luck,
    Jace Holt
    • Richard Hayes
      Before you try to pry it off- heat it up w/ a heat gun (a hair dryer will also work). It makes the prying off part MUCH easier.
      Richard
