64 coupe battery - NCRS Discussion Boards
64 coupe battery
  • robert vargas
    64 coupe battery
    Where exactly does the ground cable attach on body? I know this is a no-brainer, but I want to be sure. Thanks!
    • 43221
    Re: 64 coupe battery
    robert-----
    The battery negative cable, if that's what you're asking about, does not attach to the body. As far as I know, for 1964 it attached to the starter outboard mounting bolt (i.e. one of the 2 bolts that attaches the starter to the engine block).
    • mikemccagh
      joe is correct if its not a c-60 optioned vet in which case the neg battery cable attaches to a bellhousing to block bolt.mike
