C2 Windshield /rubber gasket sealant - NCRS Discussion Boards
  • Dave K.
    • November 1, 1999
    • 952
    The 66 judging manual indicates on page 41, "Evidence of sealant or caulking between the trim and the body is incorrect". I assume that this refers to only the trim and that it is acceptable to use a black liquid windshield sealant between the glass and the black rubber gasket? I've been told that this sealant is what the factory used to seal the windshields to the gasket.
    Dave Kitch
    33108
    Re: C2 Windshield /rubber gasket sealant
    If memory serves, sealant used between the windshield gasket and the opening of the windshield frame was a form of grey rope caulk eventhough the service manuals of the era recommended using RTV (room temperature vulcanizing) for service replacement jobs....
    • Dave K.
      • November 1, 1999
      • 952
      Jack,
      The caulk that you are referring to is strip caulk otherwise known as dum dum. I used this between the trim and gasket. I'm referring to the sealant between the glass and gasket.
      Dave Kitch
        Dave -
        I think this refers to cleanup rather than application - the entire periphery of the rubber seal to the body and windshield frame under the moldings was SLATHERED with 3710409 sealant - almost a full pound per windshield.
        • Dave K.
          • November 1, 1999
          • 952
          John,
          Di the factory apply a sealant inside the gasket between the glass and the gasket?
          Dave K.
            Dave -
            Yes, they did - P/N 9981215 sealer.
            • Jerry G.
              • April 1, 1985
              • 1022
              Current replacement sealers?
              What is a repalcement source for the 9981215 and 3710409 seal materials?
