Replace Electric Window Motor -- 72 - NCRS Discussion Boards
  • Ray Wolson
    Is it necessary to remove the window glass while replacing the driver side electric window motor in a 72 convertible? Does anyone have any tips to help in replacing the motor?
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: Replace Electric Window Motor -- 72
    One of the easiest jobs you'll ever do on a Vette. Pull the door panel, remove the access plate, remove the motor. The motor has one electrical plug and three bolts. You don't remove the window.
