C1-Polarizing the generator - NCRS Discussion Boards
  • Robert M.
    • April 30, 1999
    • 415
    On Pirkle's web site there is a tech tip "To insure the direction of current flow is to the battery." It is referring to anytime battery voltage is removed from the generator. Since I am sure all or most have battery cutoff switches that are used regularly, I am wondering how much of a problem there is of welded points or a burnt armature. I have never experienced any of the potential problems referred to.
  • James F.
    • December 1, 1985
    • 596
    Re: C1-Polarizing the generator
    Rob,
    Nor have I. Been using cut off switches since the '70's. Regards,
    • David D.
      • 330
      Rob, Without getting into theory of operation, battery current flow, etc. Others on this board may want to expand, on the reasons why.
      If not polarizing the generator, I would be more concerned with a battery explosion, from incorrect current flow, than burned points in the voltage regulator. Believe me, it can, did, and does happen. FWIW Dave
      • terry plata
        Rob, If the generator is not removed and disassembled there is usually sufficient residual magnetism to start the unit after the cutoff switch it turned back on. I have been using a cutoff on my generator car for years with no problems....Hope it helps...Terry
