C2 brake rotor splash shields - NCRS Discussion Boards
  • Eugene B.
    • May 31, 1988
    • 710
    Members,
    I am shopping for a set (front & rear) brake rotor splash shields for my '65. I would like to have recommendations about who provides the best reproduction parts?
    Paragon states that theirs have original part numbers and Delco-Moraine identification logo, made in USA for $32 each. Has anyone purchased them and formed and opinion?
    All information is greatly appreciated.
    Gene
    • 43229
    Re: C2 brake rotor splash shields
    Gene-----
    I can't advise as to the Paragon reproductions. However, be advised that the front shields do not and never had the Delco-Moraine logo on them, so don't be disappointed if you get some fronts that don't have the logo. The original rear shields DID have the Delco-Moraine logo on them.
    Also, be advised that the front shields that are available in reproduction are the 69-82 style shields. These shields are configured differently than the 65-68 style due to the fact that the spindle shaft used on 65-68 models was smaller. The 69-82 style will work on a 65-68, but they are not exactly correct. I don't know if they're "detectable" once installed on the car. I don't think that the 65-68 style shields are reproduced at this time.
    • Rob A.
      • December 1, 1991
      • 2126
      For Clean, rust-free, used originals to replate, try J&D Corvette in Bellflower CA. (800) "VETTE JD." Just tell them exactly what you're looking for. They have a building full of used front suspension parts
      • Eugene B.
        • May 31, 1988
        • 710
        Joe,
        Thanks for the reply. I forgot that the fronts do not have the D-M logo. Also thanks for the info. that 69-82 are different than '65.
        I will obtain good used shields to replate. My plater says that my originals are going to be an expensive restoration because of significant rusting.
        Gene
        • Eugene B.
          • May 31, 1988
          • 710
          Rob,
          Thanks for the tip about J&D, I will give them a call today.
          Gene
