C3 hot starting problem - NCRS Discussion Boards
  • Bruce Mitchell
    1968 400 horse (hydraulic) 427 with 3 holley 2300's and 4 speed.
    Starts fine when cold (one pump and immediate start).
    When warmed up, after stopping for a while its very hard to start, only starts if pedal is held to floor, and when it starts its very smokey and rich for a few seconds.
    So, I figured I had fuel leaking into the throttle bores when I stopped the motor. So, I changed all three needle/seat combinations, and set float levels just at or below sight holes--result, no change.
    Then, I dropped the float levels on all three quite a bit--result, no change.
    I checked temperature of the carbs themselves after I stop with an infared thermometer, and they are only at 180-190 degrees. that shouldn't be enough to cause percolation, should it?
    the carbs are very clean, and to be sure I checked the filters (bronze) and they are fine, and I ran a tank of carb cleaner/gas through to be sure. Do you think percolation (or heat soak) is the problem?
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: C3 hot starting problem
    check for warped metering bodies,main bodies where the metering bodies fit and throttle base plates.
    • Wayne P.
      • August 31, 1975
      • 1025
      Right on with the warping! The last one I fixed required .030" milling of the main body to get it flat.
      • Clem Z.
        • January 1, 2006
        • 9427
        PS if the metering blocks are warped
        you can not mill them flat they must be replaced or straighten in a "jig" using a arbor press
        • terry plata
          Re: PS if the metering blocks are warped
          Clem and company,
          Oddly enough I have seen more damage to the main body by over tightening the bowl screws. the screw holes are pulled into the soft gasket material and you have a warp. The metering blocks tend to escape this abuse because they fairly stoug, not threaded so take little stress. A straighedge across the body will reveal if the problem lies there. EASY ON THE BOWL SCREWS!..... TPlata
