C2 Cushion Assembly - NCRS Discussion Boards
C2 Cushion Assembly
  • Ron Green
    C2 Cushion Assembly
    I'm having trouble finding part # 9750078 which is the cushion assembly for the cross member for the differential. Can someone tell me of a supplier for this part?
    • 43295
    Re: C2 Cushion Assembly
    Ron-----
    As far as I can tell, the cushion is still available from GM. Also, I believe that this cushion is available from reproduction sources. Dr. Rebuild or Paragon should have it.
    • Brian Monticello
      I believe the upper is 3788637 and the lower is 3795333. Double check this - I described the parts to a shop once and when I got home and held the new up to the old I discovered they were body mount cushions!
      Brian
      • Rob A.
        • December 1, 1991
        • 2126
        I purchased mine from my local Chevy dealer.
