Removing C1 door strikers - NCRS Discussion Boards
  • Larry P.
    • June 30, 1999
    • 481
    I want to remove the door strikers and they won't give. We've tried everything we can think of. Should we try drilling the screws out? What am I looking at on the back side with damage or trouble I could get into? Painter wants them off for body work and says we will need them moveable for door adjust/align. 1960
    Larry
  • Eugene B.
    • May 31, 1988
    • 710
    Re: Removing C1 door strikers
    Larry,
    Have you tried a hand impact driver? If you are not familar with one, it is a device that has a square drive on the front (to attach your socket and bit) and the rear surface is designed to be hit with a heavy hammer. The hammer strike converts the force of the in-line blow to a screw mechanism that tightens or loosens the fastner depending on the way the impact drive is set. Go easy so that you do not damage anything.
    Good luck,
    Gene
    • Mike M.
      • May 31, 1974
      • 8396
      LARRY: gene is right on. the impact driver can be bought from snap-on, craftsman, or if you're friends with motorcyclists, they all have the tool.mike
      • John M.
        • January 1, 1999
        • 1553
        I agree. I have never seen a striker that I could not remove with my impact driver.
        Regards, John McGraw
        • Larry P.
          • June 30, 1999
          • 481
          Thanks guys, I'll try it. *NM*
