When I fill my 72's fuel tank to the max, I get a bit of dripping onto the exhaust system. Now, for some of you, that may not cause concern, but I am worried about this for obvious reasons. Other than not filling the tank more than 3/4 full, is there an alternative to dropping the tank? I believe that the leak is at the vapor condensing gizmo on the upper left rear of the tank. I really need to get in there, drop the spare tire carrier and confirm this though. I know from previous posts in the past that this fuel vapor condensor (sorry - I don't know the correct terminology) is not available in service or repro. Therefore I am stuck with fixing it, bypassing it (not really an alternative), or living with the drip (again, not really feasible). Suggestions? If I decide to drop the tank, I know that the exhaust system has to come off. I have seen the device that clamps onto the halves of the exhaust pipe and then you use a socket set and essentially rachet the halves apart. Is this the best way to get the exhaust system apart and off of the car?
Gary
72 LT1
Gary
72 LT1
