If you have these tires mounted on 6" wide factory style knockoffs, could you respond to me if you have had any interference whatsoever with your factory body panels and or suspension travel or inner wheel wells? I dont want to make a terrible mistake and mount these and end up cracking my wheel wells. Thanks for your help.
Goodyear Regatta 215-65 R15
Re: Goodyear Regatta 215-65 R15
Dino -
I've got Pirelli 215-65-15s on KOs on my '66. No problems with body clearances, but do get minor rubbing on the frame in front right wheelwell when the steering is turned to the full right stop.
Keep in mind that spring type and condition, body mount condition, plain old assembly line variability, and a multitude of other factors may cause someone elses experience to be different.
Good luck with the project.
Mike S
#33053- Top
