3461S carburetor - NCRS Discussion Boards
3461S carburetor
  • Timothy B.
    • April 30, 1983
    • 5190
    3461S carburetor
    I am in the process of trying to ID the correct butterfly valves on the bottom of my 3461S carter carburetor. The primary has a # 2-211 and is aluminum and the secondary has # 2-196 and it is made of brass. I have a 3721 SB carter that has the same primary but the secondary is # 2-28 (aluminum) but I may have gotten them mixed up. Thanks as always, Tim Barbieri
    • 15696
    Re: 3461S carburetor
    You have the correct throttle valves on your 3461S.
      • 43240
      Tim----
      The Carter 2-196 are the correct secondary throttle valves for the 3461S carburetor.
