C1 third arm question - NCRS Discussion Boards
  • Mike Nelson
    How much play is acceptable in the third arm on C1 steering? I noticed that the one on my '61 has some slight up-and-down motion to it while turning the wheels lock-to-lock. There is noticeable wander when driving down the road, and I was almost convinced it was due to an alignment problem, but now I wonder. Any ideas or comments?
  • John T.
    NCRS Financial Officer
    • January 1, 1983
    • 291
    Re: C1 third arm question
    After replacing the bearing in mine (62) I have essentially no up and down play. Good luck.
    • Tom P.
      • April 1, 1980
      • 1814
      I agree, install a new bearing, it's quite easy. The BCA part number is 5206KE. It would also be wise to order a seal (to go between the steering arm and bracket) from some place such as Corvette Central
      • Karl #35089
        what was your source for the bearing? I replaced mine and still have same vertical motion as before. -k
        • Mike Nelson
          Thanks for the positive responses. I'll definitely replace the bearing before getting it aligned.
          • Roy B.
            • February 1, 1975
            • 7044
            Also to help stop your wandering get roller bearings in front and take out the ball bearings.
