65 Power Antenna - NCRS Discussion Boards
65 Power Antenna
  • John O.
    • June 30, 2000
    • 88
    65 Power Antenna
    Can anyone recommend a good person/company for the restoration of a 65 power antenna? Mine works but the last section will not fully retract into the shaft. Also, can the people who do this kind of work re-plastic dip the unit?
    As always, thank you for your input.
    -John
  • Gary B.
    • February 1, 1997
    • 7024
    Re: 65 Power Antenna
    John,
    You should talk with Chuck at OEM Glass. Their toll-free number is 800 283-2122. As far as I know, OEM Glass is the only place that restores 65-66 power antennas. Before you call, get ready for sticker shock.
    Gary
    • Eugene B.
      • May 31, 1988
      • 710
      John,
      I believe that I talked to a guy who's name is Bob at Chicago Corvette. He said that he also rebuilds power antennas. The bad news is the price is even higher than OEM Glass.
      Gary is correct, fix an nice stiff beverage of your choice - you're going to need it!
      If you find a better deal, please post the information. Mine needs refurbished also, but I'm not willing to pay the fare to get it accomplished.
      Gene
      • William C.
        • May 31, 1975
        • 6037
        I'm not sure from your description, but if yours works, the largest section does not retract. Full down is about 10 inches up from the fender. The largest diameter section does not move.
        Bill Clupper #618
        • John O.
          • June 30, 2000
          • 88
          Bill:
          Sorry about the confusion, the last section, or smallest section is the one that will not retract fully.
          • Mike M.
            • May 31, 1974
            • 8386
            remove antenna ,take off the yellow sealant surrounding the motor, remove tin side cover then soak the mast assembly with a good penetrating lubricant. since your antenna works somewhat, i doubt the cable thats prone to rusting and which elevates and retracts the mast assembly is broken in two. you may luck out with the penetrating oil and it'll save you about 500 bucks. mike
            • John O.
              • June 30, 2000
              • 88
              Mike:
              Thanks for the post, I'll give it a shot. However, does OEM Glass reseal the units with the plastic? Or is it possible to salvage the one I have?
              Thanks again!
              John
              • Gary B.
                • February 1, 1997
                • 7024
                Beeswax sealant; yes OEM does this
                John,
                OEM Glass does reseal the unit with what I seem to recall is a wax material, like beeswax. The
                work they do is outstanding.
                Gary
                • Ken Robb
                  There are some past articles in Restorer on the 65 power antenna restoration. Don't have the issue # handy right now.
                  • Eugene B.
                    • May 31, 1988
                    • 710
                    Re: Pro coat
                    Gents,
                    When I spoke with the antenna rebuilders, they refered to the beeswax coating as Pro coat. I don't know where you buy it if you chose to open the antenna yourself.
                    There ought to be a better/cheaper way to return power antennas to operational condition. I feel like they got us by the proverbial "short hairs".
                    Gene
