68 motor size - NCRS Discussion Boards
68 motor size
  • Trebor
    Re: 68 motor size
    There is one more place to look to see if a big or small block was in your car. Check to see if front springs have there green tags still attached. This will tell you by the two code letters on tag. These tags rarely fell off because they were looped around spring and attached to itself. If tags are there post the part number or code and someone will respond with breakdown on meaning. These tags can be high inside the shock tower so look hard. good luck.
    • Trebor
      Re: 68 motor size
