BW points and Delco plug wires - NCRS Discussion Boards
  • Todd Pollock
    Re: A112HP lives!
    Hey Jerry-
    I was curious what the BW A120V crossed to. When I went into a local store for points recently they seemed seemed to be the only ones that worked on a dual point system. The box says Bog Warner Select with a Nascar symbol on it. Just curios they actually seem like a well made set of points.
    Todd.
    • Eugene B.
      • May 31, 1988
      • 710
      Re: Need Xcel spread sheet!
      Gents,
      I enjoyed this post thread regarding ignition points, but must admit it is a little confusing to follow.
      If one wants the 19-23 ounce (low RPM) point set, what is the correct Borg-Warner number?
      Also, thanks for the tip about the Delco #508N spark plug wires. I really didn't want to spend $60 for some of the other choices.
      Best regards,
      Gene
      • Franz E.
        • March 1, 1997
        • 96
        #18
        • Clem Z.
          • January 1, 2006
          • 9427
          #19
          for more tension we just backed up
          the moving point with a piece of foam rubber. helped to sabilize the points at high RPM and on drag engines we just used a double spring. i also used a home made,by me,"dwell extender" which used a SCR(silicon controlled rectifier) to close the points electrically before they close mechanically to increase the dwell for max spark energy at hi RPM.
            • 15692
            #20
            The standard breaker arm tension B-W point set is A120 or A120V for the ventilated set or A2120 for the "uniset" that includes the integral condenser.
