67 REAR SWAY BAR BUSHINGS - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    The busings I am installing on the rear sway bar are about 1/2" taller than the brackets. The bolts I am using(7/8" recessed hex w/attach lock washer) to install them (supposedly correct) aren't long enough to start in the holes and compress the busing enough to attach the brackets. I'd like to know who can supply the correct type and length bolts.
    • 43221
    Re: 67 REAR SWAY BAR BUSHINGS
    Rob-----
    Using generic longer bolts to install and compress the bushings. Then, remove each bolt one-at-a-time and replace with the bolts you have.
    • DANNY PANTUSO
      HI ROB, I HAD THE SAME ON MY FRONT BAR YOU THINK IT,S THE WRONG BUSHING, BUT JOE RIGHT, YOU NEED TO GET LONGER BOLT TO START THEN REMOVE AND INSTALL THE PROPER STORTER BOLTS IT CALLS FOR. DANNY
