1960 C1 spark plug, belt and air filter - NCRS Discussion Boards
  • erick holover
    Can anyone tell me the correct spark plug, air filter and fan belt for my 1960 283- single 4 barrel 230 HP 4 speed car? I am looking for old parts and want to get the correct ones. Thank you.
    • 43221
    Re: 1960 C1 spark plug, belt and air filter
    Erick----
    The original a/c element for your application was GM #5646306. I don't have the Delco number for it, at the moment. A later SERVICE replacement element was GM #6484295 also known as Delco A98C.
    Spark plugs were AC 44S also known as GM #5612386.
    Fan belt was GM #3759221. This is a 3/8" wide belt of 55-1/2" length. It was of "wrapped" construction.
    • Wayne P.
      • August 31, 1975
      • 1025
      Unless this is a show car only, you don't want a 45 year old belt. The air cleaner will be very hard to find(read expensive). Plugs should be easy as they fit millions of old Chevys.
      • Eugene B.
        • May 31, 1988
        • 710
        Erick,
        For fan belt, you may want to check Quanta. Their ad states: Quanta belts are licensed GM Restoration Parts and are made to exact bluepring specifications assuring you authenticity and high quality.
        I am happy with the set that I ordered for my '65.
        They list the 1960 generator belt as B-009 and sells for $29.00. Their web address is www.quantaproducts.com
        Hope this helps,
        Gene
