c1 wiper motor continued - NCRS Discussion Boards
  • david walsh
    I now have opened up the motor and everything looks good and I can manually shut off the motor. When I re-hook everything back up it seems I can't pull the plastic slide device back far enough with the cable. With just a slight amount of finger pressure pulling the plastic slider back, it shuts off. I feel I'm close to solution, however I don't see any way the cable can pull back the slider any more. Good news, motor is OK.
  • Terry D.
    • May 31, 1987
    • 2691
    Re: c1 wiper motor continued
    David
    Is everything tight? The mounting bracket, the switch in the dash, etc.? I had just the opposite problem, mine would not turn on. Turn them on manually and switch could change speeds or shut off but not turn back on. Found out at Carlisle that my plastic piece was only half there, letting cable have too much play. Your close to a solution, keep tinkering with it you'll get it.
