fan blad style differences - why ? - NCRS Discussion Boards
  • Warren F.
    • December 1, 1987
    • 1516
    I was wondering why there was a different style fan blade used between the LS5 and LS6. Was the 5 blade style used for less drag and power loss on the LS6, obviously both fan styles would work. Thanks, Warren
    • 43221
    Re: fan blad style differences - why ?
    Warren------
    The 1971 LS-5 and LS-6 did not use different fan blades. BOTH used blade assembly GM #3991420. The 1971 LS-5 WITH A/C did use a different blade assembly, though. This blade assembly, GM #3992095, had a greater blade pitch and specially configured blade end tips to reduce noise.
    • Warren F.
      • December 1, 1987
      • 1516
      Joe: Thanks for the explanation, I wondered about this for years. I've forgotten, is the "pointed blade fan" a 7 blade or 5 as well?
        • 43221
        Warren------
        The standard fan, GM #3991420, is a 5 blade fan. The LS-5 with A/C fan, GM #3992095, is a 7 blade fan.
        • Warren F.
          • December 1, 1987
          • 1516
          Joe: Thanks, again! Is the reason for the AC style fan to increase air flow and will it be a more efficient fan for cooling purposes?
            • 43221
            Warren-----
            Yes, the A/C fan blade provides increased air flow, primarily as a consequence of its increased blade pitch. The increased blade count also provides some additional airflow, but not as much as the increased blade pitch. The unique configuration of the tips was added to reduce noise that the increased blade pitch resulted in.
            These 71-73 GM #3992095 fans are long-since discontinued and are diffcult to find, even used. They sell for $500+, if you do find one.
            For improved cooling performance on 71-75 Corvettes you can use fan blade assembly GM #342715. This is a 17-1/2", 7 blade fan.
