1965 Vette directional flasher unit poll. - NCRS Discussion Boards
  • Bill Clippinger
    During the process of troubleshooting a malfunctioning directional flasher circuit, I have discovered a conflict between the wiring diagram found in the "1965 Corvette Shop Manual Supplement" and the 1965 Corvette AIM. Here's what I've found:
    - 63 & 64 WD (Wiring Diagram) and AIM show the flasher unit attached to the fuse block.
    - 66 WD and AIM show the flasher separate from the fuse black, wired under the dash.
    - 67 WD and AIM show BOTH locations, which is normal for that model year.
    BUT...the 65 WD shows the flasher as attached to the fuse block, while the AIM (UPC 12, B1) shows the flasher as wired separate from the fuse panel under the dash. Ironically, the wiring diagram in the AIM itself (UPC 12, D2) also shows the flasher attached to the fuse block.
    So here is where I need some help. I don't have access to a 65 Vette. So for those who do, could you answer two questions for me?
    1 - Where is the flasher on a 65 Vette? The fuse panel or under the dash?
    2 - If located under the dash, what color are the two wires going to the flasher? (I expect one to be brown and the other purple)
    Thanks in advance,
    Bill
    (Note - Ray Carney had a similar problem, posted May 15 2003)
  • Jerry G.
    • April 1, 1985
    • 1022
    Mine is on Drivers side councel heater panel
    Mine is a july .65 car and the flasher is just above my knee on the fiberglass panel that the heater air comes through. It's located on the outside of the panel so it's visable.
    • John O.
      • June 30, 2000
      • 88
      Same Location For Mine
      As with Jerry's car mine is also a July car and the flasher is in the same place as Jerry described. Wires are brown and purple.
      John
      • William C.
        • May 31, 1975
        • 6037
        Re: Mine is on Drivers side councel heater panel
        I've had several S/N from Dec thru March and all were as mentioned at the top of the consoleside panel
        Bill Clupper #618
        • Wayne M.
          • March 1, 1980
          • 6414
          Re: Mine is on Drivers side console heater panel
          Both my early # 014xx and late # 235xx have purple and brown wires, and flasher(s) are held with a clip on the upper LH (console) trim panel.
          • Jack W.
            • August 31, 2000
            • 358
            Mine (65) is too (same as above 4 posters) *NM*
            • Andy #28359
              Same here *NM*
              • Bill Clippinger
                Thanks for the responses! (NM) *NM*
                • Bill Clippinger
                  Hmm, I guess it does the "NM" itself... *NM*
