Lifter Hydraulic - NCRS Discussion Boards
Lifter Hydraulic
  • Jim K.
    • August 31, 2000
    • 554
    Lifter Hydraulic
    I need some advice on the symptoms of a collapsed lifter. I have had to re adjust several lifters on the left bank of a 66 327 CE motor. Without checking with a mike, I think the rocker studs are not moving, the springs are in tact, the adjuster nuts do offer resistance, but not a ton of it. After my latest adjustment (With a hot engine) I was having trouble getting a decent idle, so I shut down and checked all the plugs and did a quick compression check. Right bank 195 - 200, left bank 30, 0, 0, 200. Brought it to tdc and adjusted the #1 valves to just touching, compression came back to 190+/- did the same to #3 and #5 with the same results and all three were tightende down too far (hence the 30, 0 & 0 readings) Started it back up and got the noise out plus 12 turn tighter (I always thought it was 3/4 turn but have heard many differing opinions on that). No noise and ideling much better, but still not perfect. and haven't done a road test yet either. It's ysually after a highway cruise that I get a noisy lifter on that side. If I have a partially collapsed lifter, and adjust the noise out, can the lifter pump up and cause valve to piston problems? Otherwise, any other advice on all this fun??? Thanks in advance!!!
    Jim
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: Lifter Hydraulic
    Why did you turn it 12 turns after getting the noise out. That might explain your previous ZERO compression. One of three things, thenuts are backing off, the lifters are collapsing, the cam lobs are gone or going.
    • Jim K.
      • August 31, 2000
      • 554
      Oops, "1/2" a turn. How can I tell if the lifter is colapsing, will pushing on it (engine not running) do anything???
      • Eugene B.
        • May 31, 1988
        • 710
        Jim,
        The procedure that I have always seen performed to adjust hydraulic lifters is ONE FULL TURN down from zero lash. The exact procedure is documented well in the 1963 shop manual on page 6-14 and 6-15.
        Good luck,
        Gene
        • Joseph Sanfilippo
          Jim,
          Is this the base engine that you are talking about? If so, and it has the .390/.410 lift cam, there is a good possibility of a bad cam lobe. I have had 2 Vettes, a 1980 and a 1967 with this cam, and have had that problem twice. Good luck.
