1967 Ball Joints - NCRS Discussion Boards
1967 Ball Joints
  • Joseph Sanfilippo
    1967 Ball Joints
    Thanks to the guys on this board, I was able to safely remove my coil springs. Now for my next problem. I cannot get the lower ball joint to release from the steering knuckle, and I would like to know the best methods for removing riveted ball joints, and the bushings from the a arm shafts. Thanks
  • Jerry Clark
    Re: 1967 Ball Joints
    Joe:
    grind the rivet heads off the ball joint with a wheel grinder. A press is by far the easiest way to remove the A frame bushings.
    Best of luck
    jerry
    • Gary B.
      • February 1, 1997
      • 7024
      A long pry bar
      Joseph,
      To get the ball joints on my '66 to release from the steering knuckles took quite a bit of force using a very long pry bar. No way I could get them to budge with a standard pickle fork and medium sized hammer. They just wouldn't budge that way.
      Gary
      • Jerry Clark
        Re: A long pry bar
        thanks Gary, forgot the knuckle
        jerry
        • Patrick T.
          • September 30, 1999
          • 1286
          Here is how I removed the bushings from the A arm shafts. It is the easiest way.
          • Wayne W.
            • April 30, 1982
            • 3605
            A sharp whack on the knuckle with a large hammer, perpendicular to the taper. Will release them every time.
            • Craig S.
              • June 30, 1997
              • 2471
              Patrick - that way is fool proof! But it's outside operation only with the black rubber smoke that is already gone in your photo! Nothing like a gas axe....Craig
              • Richard W.
                • June 30, 2000
                • 84
                Suggestions re ball joint release and bushings
                I had a similiar problem when the idler arm would not separate from the center link on my '63. I finally took it to a local tool/machine shop with all kinds of machines. Whatever they did, it cost me $5.
                Re the bushings, I researched that a lot. In the end the answer was simple. I just walked the bushings out by holding my air chisel against the outter flange of the bushing. Took about 1 to 2 minutes per bushing. As an aside, I read that buring is dangerious because the rubber can explode (no actual knowlege).
                Although you did not ask, installing the new bushings was a snap. Roughed up the bushings with sandpaper, cleaned up the hole, put some grease on the bushing and pounded the bushing in place using a 3/4 drill bit that was large enough to cover the outer flange (cost $5). Just alternate each end using the center bar to guide the bushing into place. Make sure they are going in straight.
                Dick
                • Eric Fairclough
                  Re: Suggestions re ball joint release and bushings
                  I drilled holes through the rubber all around on my control arms then twisted and pryed it out with a big screwdriver. It went very quick. Eric
