C1 Wipers - NCRS Discussion Boards
C1 Wipers
  • Tom Murphy 38312
    C1 Wipers
    With Hurricane Isabel bearing down on us this week, I had my first ever opportunity to use the wipers in my '60. I tried twisting the knob, then pulling, to no avail. I then pushed the washer button (no washers installed) and Voila!, they started working. Now I can't shut them off. Can anyone shed any light on this subject? How is the knob supposed to work? Any other suggestions (other than move to Seattle)? Thanks
  • Gary Bishop
    Re: C1 Wipers
    Could be where the beldon cable attaches to the wiper motor.
    • Ed Jennings
      Re: C1 Wipers
      The knob pushes and pulls a cable attached to a plastic slider on the motor. The plastic piece actuates the switch in the motor. The cable may be loose where it is attached at the motor, sort of like a lawn mower throttle cable.
      • Tom Murphy 38312
        C1 Wipers
        Thanks Gary and Ed. I'll definitely have this fixed before the next hurricane
        • Doug Flaten
          Re: C1 Wipers
          Quick Lazy way to turn them off is to reach under and pull on the whole cable. It may work if it is just a little out of adjustment. It is not the "fix" though
