New Instrument Cluster Observations - NCRS Discussion Boards
  • Tony H.
    • May 31, 1993
    • 537
    The new instrument cluster for my 1970 arrived this week. I finally got a chance to remove my old modified one and compare it with the new one. Very interesting. The black paint on the new one appears to be too glossy. Is it supposed to be semi-gloss black? Is this color readily available at K-mart or Walmart, etc? (Krylon semi-flat black #1613???)
    Another big difference was the spring for the seat belt button. The new button supplied is slightly different than the original in shape (exact dimensions are slightly off) and finish. The original is shiny while the new button has a matte finish.
    The new button retainer is of different configuration. I'll have to write a Restorer article on this to give all of you a better description of what I have observed. Basically it is a donut that slides over the button shaft from the back side of the bezel. It appears to be a light gray flat stamped steel ring. The original is black with four internal prongs that secure the button shaft.
    The new spring for the button is zinc plated metal with a much lower spring constant with about twice as many coils as the original steel spring.
    In order to make the seat belt lens fit in properly, I had to modify the new cluster bezel to accept the lens. (I prefer not to modify original parts like the original lens). I used a dremel tool to do this.
    I photographed the buttons and components side by side before my 4-year old son lost the new spring. (That's OK, it felt like junk any way compared to the original spring.)
    While I was at it, I removed the radio and repaired the loose ground. Hopefully this will fix my radio. As soon as I get the correct black paint, I will paint the masked bezel and proceed with installation. With modifications and reuse of old button and spring, the new instrument cluster will look as good as original.
    Tony
  • Tony H.
    • May 31, 1993
    • 537
    Re: New Instrument Cluster Observations-Addendum
    I installed the new instrument cluster and now the seat belt button (original) does not work. The seat belt light remains on. I am in the process of removing it again (oh joy!) to either modify the socket or to replace the original button with the repro. I will use the original spring to maintain the original feel when depressing the button. I could and should have tested this before I completed the installation. Oh well, live and learn. I hope all others who read this "learn" the easy way, through others' (my) mistakes.
    Tony
    Tony
    • Tony H.
      • May 31, 1993
      • 537
      Tony
      Tony
      • Tony H.
        • May 31, 1993
        • 537
        Re: New Instrument Cluster Observations-Fixed
        Well, the solution to allow the seat belt light to turn off when pressing the button was to lengthen the original button shaft by about 1/30th of an inch. It was actually not that hard as I was able to tilt the bezel out of the dash and remove the circuit board of the seat belt button. I then glued (using model cement) a piece of plastic that was about 1/30" to the end of the button shaft. I tested it and it worked!
        The radio still doesn't work though.
        Tony
        Tony
        • Tony H.
          • May 31, 1993
          • 537
          Tony
          Tony
          • Chuck G.
            • May 31, 1982
            • 2034
            Hello Tony; Glad to hear that one problem is solved. Regarding the radio, if you want it "fixed" and not necessarily "restored", bring it down to the drag races at Cecil County Dragway next week. Dave Frazee of "CARS" (Classic Auto Radio Service) in Frederick, Maryland can check it out and repair it for you. His turn around time is pretty quick. If it's not an internal radio problem, you'll at least have the peace of mind knowing that it's an external problem....power wire, ground, etc. Let me know and I'll call Dave. I can drop it off for you. Chuck
            • Chuck G.
              • May 31, 1982
              • 2034
