Tailering 1960 - NCRS Discussion Boards
Tailering 1960
  • erick holover
    Tailering 1960
    As for tying down the car, I was told to tie the car down by the frame. Should I tie the rear down by the frame(in front of the last crossmember)? As for the front, since I cannot get to the frame, should I use a tire tie down(a strap net that goes over the tire)? Thank you.
  • Mike M.
    • May 31, 1974
    • 8383
    Re: Tailering 1960
    i tie my c-1's down at four points. one on each side of the rear axle and one thru each lower A-arm up front. i usually cross the fronts. mike
    • John M.
      • January 1, 1999
      • 1553
      Re: Tailering 1960
      I agree with Mike. That is the way I allways tie C1 cars down as well. You almost have to cross the front straps to keep the straps away from the body under the radiator. I use short axle straps on the front and rear that have a free-floating protective sleeve on them to prevent chafing. You should be able to find them almost everywhere.
      Regards, John McGraw
      • Dennis C.
        NCRS Past Judging Chairman
        • January 1, 1984
        • 2409
        Re: Tailering 1960
        Mikie, Do you also suggest latching and locking the rear door of the trailer, or have you just learned to also tie down your suitcases ??? And, have you ever had a car exit the trailer because it was not tied down at all??? I'm sure your friends here would love your comments on these two issues. Your close friend in Lyle, WA
        • Dick W.
          • 10483
          Re: Tailering 1960
          Dennis, would this post have anything to do with a highway full of luggage somewhere between Anaheim and Cumberland????? And a Coca Cola drink box on wheels full of dry ice?? Darn, we uns is a gittin' old, but a lot of good memories
          Dick Whittington
          • Dennis C.
            • January 1, 1984
            • 2409
            Re: Tailering 1960
            Dickie - You got that right. Best, Dennis
              • 15600
              Re: Tailering 1960 *TL*
              Part of the story (not the Anaheim part) will be in the next Restorer, with Mikey's by-line.
