On the driver's side inner fender is the horn relay in my '58. The wire terminals are toward the engine. The red wire is in the middle, but is the tan or black wire toward the front? Thanks!
C1 Horn relay wire order
Re: C1 Horn relay wire order
Delco made it simple.... Look at the cover and you'll see stamped annotations 'S' and 'H' which are 'doubled' so they point to the correct terminals regardless of the orientation of the cover's installation on the relay base. S= 'switch' and H= 'horn'....- Top
Hey, that's pretty cool!
I knew from the wiring diagram that I'd connect tan to S and black to H, but the cover has both S and H on both sides, so I was confused. Not until you explained it, do I see why. Pretty clever!
Thanks to both Jack and Ed! It's hooked up now.
- Mike Greene- Top
