70 LT1 Rear-end-what ratio? - NCRS Discussion Boards
  • John Fulton
    lt rear end what ratio john fulton what was the the default rear end on the lt i say this assuming there was one i have looked at the window sticker and there is none listed as an option so i assume there was a standard equipment one for the lt
    • 43239
    Re: 70 LT1 Rear-end-what ratio?
    re lt rear end what ratio joe lucia lt s were orderable with a wide ratio or close ratio speed transmission if the wide ratio was selected the standard rear axle ratio was if the close ratio was specified a axle ratio was standard
