1973 Inner Fender Dust Shields - NCRS Discussion Boards
  • Tim Keeler
    Can anyone recommend a supplier(s) of correct inner fender dust shields ? I replaced the torn originals several years ago from a mass Corvette parts supplier, these have a thickness that can be compared to a heavy duty mud flag for a semi. The original thickness is about 1/16". I'd like to get exact repros or excellent originals. Any thoughts ? Thanks, Tim # 26883
    Re: 1973 Inner Fender Dust Shields
    Haven't seen any problems with Paragon/C-Central/Dr. Rebuild and suspect you might still be able to get from/through Mr. Goodwrench. Have you tried?
        • 43221
        Jack----
        The shields are still available from General Motors under the part numbers 3947933 (left) and 3947934 (right). However, although available under the original part numbers, the material used for the shields is different. The current material is slightly thicker than the originals and has a different surface configuration. I've found the Dr. Rebuild repros to be much closer to original.
          • 43221
          Jack----
