1967 fuel guage - NCRS Discussion Boards
1967 fuel guage
  • Phil A.
    • April 30, 1982
    • 121
    1967 fuel guage
    The guage was restored by Rogers Instraments and reads oppisite from what it shouldindicate. When on empty it shows well below empty, when on full it shows just up on the 'E'. Could the prongs on the back of the guage be installed backwards where the harness plugs into it,giving the oppisite indication? I hooked a new sending unit up outside the tank to the wiring harness to operate the guage. Thanks Phil Anderson
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 1967 fuel guage
    Where does it go with the power off? Make sure that you have it hooked up correctly. You could have the wires reversed. That is what you have to do to make an aftermarket guage work, because it is backwards.
    • Kent K.
      • December 1, 1982
      • 1139
      Re: 1967 fuel guage
      Phil,
      Simply call Roger about which wires connect where. He is a professional engineer with a specialization in instramentation who has lots of patience and understanding for those of us who are in a hurry to piece it back together. OR, check your wiring diagrams in the AIM.
      Good Corvetting,
      Kent #6201
      Kent
      NCM Founder - Member #718
      • Phil A.
        • April 30, 1982
        • 121
        Re: 1967 fuel guage
        Wayne, thanks for responding to my post. The sending unit is a NOS unit. When you turn the power off the needle doesn't move.It only moves when you operate the float up and down, and then only from the top of the "E" to way below the "E" with the power on. It also operates oppisite direction from the travel of the float. Thanks Phil
