1960 aluminum heads - NCRS Discussion Boards
1960 aluminum heads
  • GL Anderson
    1960 aluminum heads
    Does anybody know the casting numbers for the 1960 aluminum heads? Thanks GL Anderson
    • 43221
    Re: 1960 aluminum heads
    GL-----
    The 1960 aluminum cylinder heads carried casting number 3782461X. This same casting number was used for some 1960 and later cast iron heads.
    • Dennis C.
      NCRS Past Judging Chairman
      • January 1, 1984
      • 2409
      GL - Don't let any response lead you to assume these cylinder heads were ever attached to an engine delivered to a retail customer. Dennis
