Re: The infamous distributor drive gear dimple
You are correct, Kevin. The logic from my previous post (which I deleted) applies to gear ratios that are non-integer values. With a 13/26 tooth count or any other integer ratio, teeth on one gear will only mesh with certain teeth on the mating gear. This is why most gear ratios are non-integer, however, in the case of the distributor it must rotate at exactly one-half crankshaft speed.
Craig's question: Why is is the distributer drive gear and odd number of teeth remains unanswered. Installation of the drive gear could have been made "idiot proof" if the number of teeth was even and the roll pin hole was drilled symmetrically relative to the tooth pitch.
