76 StringRay - NCRS Discussion Boards
76 StringRay
  • Al Simmons
    76 StringRay
    First Thanks for all the info on those rear brake. Resolution: Replaced master and will be replace calipers all around. My questions are: (1) My tach does not work, the needle is all the way to the right on the gauge. Is the tach broken or is their a something not connected. The assembly manual does not show much.(2) The Temp gauge does not work. Is it the gauge or the sending unit. I pull the gauge and everything was hooked up but what does that tell me
    Thank Again this site is the best
  • Paul B.
    • April 30, 1995
    • 482
    Re: 76 StringRay
    Al, those '75-'82 tachometers were electric, not mechanical as in '74 and earlier. One of the main problems that do go bad is the circuit board. I've seen these boards for $59.00 and up. There is also a person in the Driveline out of Pennsylvania(Center Valley I think) named J. Gardener who for $79.00 will rebuild and recalibrate your tach with a one year warranty. He does beautiful work(did two of mine). The fun part is removing that tach!!!
    • Paul B.
      • April 30, 1995
      • 482
      Re: 76 StringRay
