Crank Scrapers - NCRS Discussion Boards
Crank Scrapers
  • Joe C.
    • August 31, 1999
    • 4598
    Crank Scrapers
    How will they affect engine output? Can and should I use them with the original windage tray? If they are worthwhile installing, then where can I get them?
    Thanks in advance.
    Joe
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Crank Scrapers
    they do not do much till the 6000+ rpm,i would just stick with the windage tray. they can be bought from moroso. i have only used them with oil pans that have a special side pocket for the oil to go.
    • Joe C.
      • August 31, 1999
      • 4598
      Re: Crank Scrapers
      Thanks Clem. I have to remove the pan to install the windage tray (which I omitted originally), so thought that while inside, if there was anything more I could add to beef up the bottom end.
      BTW: This all started with a broken dipstick tube. Maybe that was all for the best--the tube and gauge rod were "wrong" anyway. So, one thing leads to another.
      Joe
